Luca A
I recently started using inventor 2020 for work, we mainly produce sheet metal components and sometimes tubular.
in these days I have read and sought many discussions but still unfortunately I have not managed to come to the head of my problem or: exists a way to insert in a set (a) other assemblies (b) of various sizes without having to create a dedicated file for each set (b)?I explain better by bringing a fairly basic example:
between the various components we produce insulated panels in rock wool, I started drawing a .ipt with inside the shape of the flank with defined measures "width" "altezzaf" e "spf", then I drew all the reinforcements and coatings that make up my flank, resulting from the file I had created and put them together in an iam and consequently idw.
here everything works wonder in fact changing the base file everything updates automatically but if in a set I need to put three sides (along with other pieces) for example n°1 pz 1200xh3000xsp50 n°1 pz 560xh2100xsp50 n°1 pz 1040xh1700xsp50
(we have a very out of standard production and really you can have to insert many components all of different sizes)
Is there a way that you automatically create me flanks with input measures referring to the same reinforcements so that if a tomorrow change a reinforcement bend will update my projects?
right now for how I structured the thing I should for every side model copy practically all the side design and change measures but I hope someone knows how to recommend a faster and more efficient method.
I also tried to use iparts and it works well on the parts because about it does what I would like or at the time of insertion I can give them different values in the columns that I set as free and automatically creates a "under part" with the updated measures but I did not really manage to come to head with the axieme, iassembly does not seem to work properly for my need.
ps: besides the structure would already be a welded assembly but for the moment I had to remove the welds because it did not update them correctly, but this I will try to solve it later.
Attached a bit of work screen that I am running.
