solid problem that disappears together
  • Thread starter Thread starter mariozz
mariozz
Good morning.
I am new to the forum, and also to autocad..
I have a problem, I designed in 3d the essential parts of a motor, that is, camshaft, piston and uncomplicable biella.
Now I am doing the assembling but mating the two parts of the biella I realized that in the body part it is impossible to find snap points....
In fact, passing from realistic view to wireframe, practically the body of the biella disappears. . .
What can I have done?
Thank you very much
video allego.
I don't know, you should check the file, as I do not exclude any software and hardware possibilities. Can you download it?
Anyway, in my opinion, for something so you'd better use inventor.autocad on complex solids is not that it's great.
Here's the file..
Yes, in fact better inventor for these things but I am doing training on autocad.
command: _audit
correct any error found? [Sì/No] <n>:
header verification
verification of tables
verification of phase 1 entities
phase 1 100 controlled objects
verification of phase 2 entities
phase 2 100 controlled objects(6e6) cannot be repaired. will be deleted.
block verification
1 verified blocks
verification of acdsrecords
total of 1 errors found: 1 correct
Deleted objects 1</n>
command: _audit
header verification
block verification
1 verified blocks
I'm sorry, but I can't understand, I've run the command, but it erases my object.
What is not clear to you in this line:"phase 2 100 objects controlled tiacdb3dsolid(6e6) cannot be repaired. will be deleted. "?
means that the solid has a problem that cannot be resolved and then it will be deleted.
in money, you have to do it again
ok. ti ringrazio.
in the file that you attached the solid that you disappeared was not modeled (there are a polylinea and a circle)
Yes. I can't understand what happened... However being a simple and quick thing to do I did before doing it again. .
