and
Hello, you can print a drawing in .pdf format and when I open it with acrobat or other .pdf programs recognize me the texts that are in the drawing as written and not as lines?
Usually when I have to copy texts from pdf I open it with pdf-xcharge that until release 7 had the ocr conversion also in the free version, and from there I have all the selectable texts, even better can be ashampoopdf than in the free versions besides the ocr technology there is also the possibility to edit the texts directly, the only "fastidio" is that sometimes you open advertising windows.Hello, you can print a drawing in .pdf format and when I open it with acrobat or other .pdf programs recognize me the texts that are in the drawing as written and not as lines?
I tried with the arial font, one of the most famous, and it does not work, I read on wikipedia that "was format distributed as "true type, 1990 e come Postscript in 1991", does it mean that it is no longer truetype and that is why when we press it is not recognized as text?if you start from a new document, it is preferable to use tt fonts, called “true type” which are part of windows, qualitatively better and recognizable as text in pdf generated.
hi, I just tried with arial filling on but to me with annotation does not workthe best known usual: arial, calibers, verdana etc. when imposed by creo dm you have to choose the option "pieno on"
Yes, as I said annotation only print the vector pdf. in annotation you must set the arial font, save the table in dwg, reopen it in autocad, print in pdf and finally the font should be recognizable. . . .hi, I just tried with arial filling on but to me with annotation does not work
