prefectious text blocks
  • Thread starter Thread starter Lorenz578
Lorenz578
Good morning.
can you create default text blocks?
practical example:
the word "unquoted bevels 1x45°" I must always insert it in the cartilage and every time I have to rewrite the text by hand.
is there the possibility to create a block with this (or others) text? then recall it through a selection of a command (for the purpose blocks) and insert it into the drawing format.
I think you can add a sketch symbol with that text (symbols of sketch / define new symbol), and then insert it to need.
Okay, it works.
to be able to recall it in other tables, I have saved in the library symbols.
I have noticed that with respect to sw (used for 15 years) certain functions with inventor you have to create a little 'yourself';)
the important is the final result
It's just a matter of habit. I happen the reverse situation to me, i.e. years of inventor, with sw I find very bad because for me it is not intuitive.
the speech of the little intuitive is only because, as you say, it has been used for years to always use the same product and when you go to a new one it seems that everything is out of place.
for my experience (I use inventor for about 6 months), in some sw and inventor things they look like and somehow you can get there without great difficulty, in other words I inventor requires more steps than direct sw commands.
But it's like you say, it's just a matter of habit.
bye;
I have set a custom property on templates (renamed later on the chart), called "smussi_non_quotati".
Then I have another "non-quota" connection.
I was doing the same thing on solidworks.
