insert horizontal/vertical odds with just one click
  • Thread starter Thread starter Mano63
to me not from problems (vertical and horizontal choose it alone. I think it depends from where you click).
... I correct myself: I also do not always work (see attached dwg - lower part of the planimetry)
..even adding the two variables, in the circled area of the planimetry the vertical quota indicates 0. I don't think it's a polyline problem (I tried to erase three quarters but in that situation the share doesn't work. for me is a mystery. in the upper part everything works perfectly and the added entities (polilines) are absolutely identical to the first.
I'm there! I think that's the problem. if the polylines have coordinates y negative the odds do not work. I think they always work in the x positive y positive dial.
..it is not true either the history of the bird or I try again a little for the whole Cartesian plan and at some point it started to work also the vertical quotation (the horizontal one never gave problems). I can't find out what could be the problem at the user level.
simply fantastic gp.!... you also set the odds below 3000, which now color red.
I'm going to devise something, but for now I can only propose myself as a "collar".
Thank you!
Okay, thank you. In fact the files I deal with are a little more complex than drawingz.dwg. polylines often compose groups with other entities: lines, data fields (testom)... I'm still trying the command, and I found out why it works properly I need to use it by deactivating groups. Once the quotation is finished I have to reactivate the groups and so it will be all perfect!
....the lisp is taking me, but I don't understand anything... .
However I managed to transfer the codes to have the quotas below 3000 in red within the quotaov lisp provided by joblayer both for horizontal and vertical quotas (and it works!!)
in quotaov there is the advantage that the quotas remain "attached", so they automatically update in case of movements / withdrawals of the polylines. applause also at joblayer!
@gp:
If you are so susceptible, I have other themes to provoke you.. . .
but already instead of my finger I took a forearm. . .
I thank you for the applause, even if I think that the gp lisp is leaner and more professional than mine, but if to train you to the study of the lisp you happen to use quotaov, I realized that it is advisable to line 28 (setq sdis nnnn) always add ".0" i.e. ==> nnnn.0 as the whole numbers above 32384 are not manageable and an error is generated.
