step
good day to all, I take care of oil&gas and I need help, can you parameterize a threaded hole in inventor like all other processing?
2 things:good day to all, I take care of oil&gas and I need help, can you parameterize a threaded hole in inventor like all other processing?
I think there is no Italian translation for those who work in the oil&gas sector :biggrin:if you perform your profession in Italy, you can also ski it in Italian in your user profile
petrochemical I think it might be okay.:smile:I think there is no Italian translation for those who work in the oil&gas sector.
I fully agree. They are also strongly opposed to polytechnic inlay lessons. already is difficult matter. If then we have to compare with a language not ours at home... there is no wonder that the contents fall... end ot.petrochemical I think it might be okay.:smile:
However, "instrumentation products for application in the power, chemical and petrochemical industries" is translatable:
" instrumentation products for energy, chemical and petrochemical applications"
Here, even the google translator can.
apart from the jokes, :biggrin: It's just a small personal battle against the use of English in Italian relations.
English that, without reference to anyone, we are good at spreading among us and very ignorant when we have to use it with them.:angry:
end of ot:smile:.
That would be a great idea! You'll see how everyone's running to help you! Maybe they'll come from the rest of the world...:tongue:and what would be the right section? I've known this site recently...
My profession takes place in the world.
You're right, I could write in Italian but also in Chinese.
if during the registration you read the forum rules and take a look at the inventor section (as well as the others) ... you would have found it quietly. Hi.and what would be the right section? I've known this site recently...
the fact that it can be used are in agreement but that it is a true parameterization cannot be said.? ? ?
the holes inserted use the same sketch and the condition active or disables the view if they are few holes from handles you can safely use.because you pretend you have not seen nn understand...:biggrin:
I'm going back to the discussion. Since it's been 10 years.... is it possible now to do it with inventor 2022?I wasn't clear.
by parameterization I intend to create a excel sheet with tables and values associated with the odds of a 3d model. varying the values inserted in this excel sheet the 3d is updated... for all quotas and processing I did not find problems to associate them but for threaded holes something does not work.. .
in my case i'm trying to "pilot" a set of a hydraulic cylinder with a spreadsheet. the problem that the only parameter i miss is the threaded hole (type/size/dseignation). from parameters, i see only the depth and anglei try to respond even if i have not understood what you want to do .. if you intend to file a hole created with the command "extrusion" the problem persists also in 2022 as the thread does not find the right "preforo" and they change both .. for all the rest there are the hyphaeations with which you can create any type of threaded hole parameterized but especially customized .. create the point and insert the end. is not said that a hole "extruded" i want to file it regardless and with the threaded command i also make the foreskin .. the speech perhaps changes if we want to create threaded bars where the outside i have to coincide with the ø of the stem before the thread .. but change both is question of 1sec. is worth it???
