parameterization of a thread
  • Thread starter Thread starter step
excel sheet is the table of an iassembly or have you developed the hydraulic cylinder axieme by reducing it to an ipart? .. excuse me is that for me the cylinders are all axiemi, including representations of positions, if I try to fly it with a simple file of excel becomes a unique part .. I also press that ilogic do not know it and the 3 commands I use made them create from my supplier cad.
no, no iassembly/ipart. is a simple set with two parts (stelo and canna)
excel sheets connected to the inventor parts I know only those of the iparts or the management of points .. I am trying to understand, also because I would learn something, as you are using this system but I only produce details based on inv parameters and not based on excel tables linked to inv
design the particular, go to the board manage/parameters from there change/rename values. create a excel (with the same names you gave the parameters in inventor) and color them. then down to left from the inventor parameters you have the button link. connect the spreadsheet and indicate from which cell should begin to read... cmq is easier to make than to say. .
now I understand .. in fact I never used it .. and there is no column of the thread .. we update
ok .. unfortunately, the threads are connected to the norms present in the file of excel that determines them .. it is not possible the presence of this column in the "parameters" .. also in 2021/2022 for now there is no solution but I do not think that they take it even in consideration since it is a ray problem with the other commands.
