Tarkus
as from title,:
I have to make a sheet folded to "top": I make a banal sketch of a "v" (2 lines equal to 90° each other), and the serialization to have the profile to be created.
I use the "flangia contour" command on the sketch, but it makes me select only the first two lines. I go back to the sketch and I see that there is no linkage between one and the other.
Try to put them by hand, even if I have to do it for 35 occasions, but it tells me that the sketch is hyperwinked.
I then tried to make a circular series, or a mirror with this and other sketches, but the result is the same not connected by constraint of coincidence. .
How to ovviate?
Am I wrong?
How to ovviate?
Am I wrong?
