create notes with guide with components parameters at the table together
  • Thread starter Thread starter Viollo
Viollo
Good morning, guys.
as from title, I need to create, in my table of a set, notes with guide that automatically show parameters related to the components of the axieme (e.g. code, weight, description, material, etc...)
In practice, in the end, I would like to find myself with my table representing a set, and to each component a note with guide where you show me some parameters related to the component, which is automatically updated if I had to change the parameters.
is it possible to realize it?
Thanks for any answers and good day!
you can do it using an ad hoc bubble symbol, but still resting on a repeat table together (which at the limit is outside the print area).
Good morning to both of you.
I join the debate for a similar question.
I would need to create notes that refer to the codes of the components that make up the axieme, automatically writing the code of the individual components.
I give you an example:"to form the couple use the raw xxx and yyy", where "xxx" and "yyyy" indicate the codes of 2 components present within the axis.
I imagine there is a syntax that allows me to automatically withdraw the corresponding parameter and insert it into the text note.
Can you help me?
you must look for the session_id of the pieces:
#relationships
#visual
#session_id
select the piece
in the mix line there is the number of the piece (for example 12 and 15)
to form the pair use the roughs &model_name:12 and &model_name:15
hinges
#relationships
#visual
#session_id
select the piece
hinges
Thank you very much @arni1! I followed the directions and managed it without problems!
also for the number of components within the axieme can I use a similar systax?
the name of the quantity of objects within a set where I can find it?
