I apologize ....claudio from thermoli, version 2021, I wanted to post it the file but it does not charge me. I put it in dwg if it can be useful. I practically did the cames sketch, then I used the wind command and the sweep command....but it comes abnormally.First of all, say hello and maybe we introduce ourselves... and finally thank you
What version of solid do you have?
if you've already sketched something, let's see how to fix it without having to start from scratch
You can also help with pictures.using the sweep, the cut is not regular but leaves a tooth
because it is a function, as written in the guide:rules of sweepI don't understand why you don't pick me up as a path
I didn't understand, explain better pleaseSorry if I come in, but with that sketch you can possibly create a solid that goes to dig with merge bodies
with the sketch path creates a solid and then matches it, with the option to remove intersection.I didn't understand, explain better please
for the method I proposed:What are these commands? Maybe I do.
I did but I always have the same problem, i.e. I can't select winds to do the sweep. I attach the file saved in solid 2013 if someone wants to try and then repost would make me a pleasure.for the method I proposed:
- create the sketch on the cylinder and wrap it as you have already done
- instead of cutting, make it solid and put the check not to join the bodies
- use the matching function
I add a comment: sweeps on curves can be doneThat file is a brothel.. .
However, you do not have to use the winding function to make the cut, but to create the path. remove from the sketches the shape you want to get and keep only the axis (which you have to turn into normal line) and then try both with rashes, but also with curve> projected.
at this point, as a curve cannot be used to sweep, through the schzzo 3d transform it into a selectable path.
allego files in 2019
