dynamic block for greenhouse quotas
  • Thread starter Thread starter MickSenna
MickSenna
Good morning to all,
I'm new in the forum so if I'm wrong you'll pay me.
I have searched long and wide on the internet to come to the head of a simple but not trivial question. my need is the insertion of a dynamic block to quota doors and windows in the plane. I can insert attributes, parameters and everything I need. the problem arises when I have to rotate the block. as best evidenced by the image attached the texts of the quotas are inconsistent, specifically the quotas on the north and east side are correct, while those on the south and west side are badly oriented. I tried to solve with a "flip" parameter without results. Does anyone have a solution?
p.s. I can not solve with matching text orientation with layout due to an old plotter set with horizontal and vertical inverted :confused:
you must use the wheel parameter and then associate it with the wheel action with center between the two odds.
in this version I have integrated a data field to define the width.
ps. for laziness I renamed the file but not the block, be careful.
I think I understand what you want from the block, but it doesn't work to me:
the block modified by lattu works well, to update data field you need to use command
"_updatefield" after stretching line on the fixed shoulder
exact, you can also make a rigen occasionally, I tried to add it to the block but I did not find the way to automate the update of the data field
