copy and paste exploded configuration to get 2 different explosive versions: possible?
reggio
hi, I would like to understand if you can copy and paste an exploded configuration to get 2 different versions of explosives, modify some measurements of an explosion using everything else.
In this way I could get 2 different boards with some parts in different positions without having to recreate the explosive from scratch.
Is there a way to do this? :
I don't know, did you just try to do ctrl+c ctrl+v?
the configuration does not work
for now the only solution would be to copy the file together and change a few steps, then to connect to the original table, the exploded of the copied and modified axieme... but it is also stainvellico only to describe it .. :
I found this, but as I do not use more solid (I would have to update the profile, but I am lazy and smemorate) I can not do verification
:roflmao:
I swear I hoped I had tried and my sw2016 didn't work...... but after your intervention ... actually ... it covered/paste ... il
. Do you realize that if I added "old and reluctant" you would have done my photograph? :giggle:
good holidays to all of you ohhh wise patients
