tanticapelli
hello to all, I open a new question to which I have not yet been able to find answer.
Sending sheet coating typical of building enclosures.
I press that the sheet is "ingenierized", in the sense that once flattened it can be thrown directly into laser cutting and bent.
is parameterized in order to preserve its external dimensions also varying sheet thickness and rear bending radius.
the problem is the small triangles that I can't build without mistakenly sending the functions (and already work normally with "reconstruction (active control of the advanced body)" disabled).
in the file you find in the annex I have adopted some stratagems not to mistakenly send the feature manager and thus succeed in flattening the sheet, but unfortunately the flattened presence "defects" in the meeting points of the folds that to the one who produces the plates creates problems (it must be to manually manipulate the dxf of the flattened to eliminate these defects).
I send screenshot to make you understand what I mean by "defects" at the meeting points of the parishioners.
the question is therefore how to obtain a sheet with this foggia and not susceptible to stretch of the external silhouette to the vary of bending radius and/or thickness obtaining a flattened without defects.
