moving file properties
  • Thread starter Thread starter Alberto.rossi
Alberto.rossi
Good morning to all, I am new to the forum I decided to enroll because I find very interesting .
I'm following the implementation of the pdm in my office and I'm in front of a big obstacle, before we used the tab builder to compile the files and I hoped to be able to exploit this data for the automatic compilation of the pdm datacard. However I agreed that in creating the tab builder it was made a mistake, some data are put on custom properties and a little on configuration specifications. I would have the need to move the configuration specifications on customized ones, if someone had an idea to solve this problem I would be grateful and would raise me from a nice job to manual.
Maybe if you specify what software you are writing would be easier to understand what you are talking about.
maybe there is also the section dedicated to your software; in case you do not open a new discussion but ask moderators to move it
works only with the parts, as was required by the user marmax, but editing it can also be used on assembly files
Thank you very much for the answer, I did a test but it doesn't work to allegar you the mistake that gives me,
Modified, it stopped when it did not find properties in configuration specifications.
after copying does not delete properties from configuration specifications, if you want to activate the function remove the initial apex on this instruction
' swmodel.deletecustominfo2 defeats, names3(j)
now works thank you very kind
Staff online
