origin problem
emanuele grasso
when I view in projection with the "front view" command puts the turned base of some degree.. I think it's a problem of origin
Is there a way to put it "correct" in order to see a view in the plant as you must?
Hello emanuele,
the axieme has its own spatial orientation (the one you see from the bottom right).
the first component you insert is automatically aligned to the inside of the axieme, but it can be freely moved/ruoted, if it is not isovincolato (I think it is your case).
When I find myself in your situation, I proceed as follows:
  1. insert a new part into the axieme
  2. to the message to define the point of origin click "no": In this way the new part is aligned to the reference terna of the axieme.1650987463517.webp
  3. block the new part
  4. align mine together with the new part (you need to understand which component to bind, even according to the components you have available)
  5. Optional: you can block a part of your set and delete the auxiliary part you created at point 1.
There will also be other quicker methods, but at the moment I don't think of it.
I hope I've been helpful
Hello emanuele,
  2. to the message to define the point of origin click "no": In this way the new part is aligned to the reference terna of the axieme.View attachment 65377
But I'm a message when it looks exactly?
because I don't remember seeing him yet di
If you just need to align so that it is orthogonal.. just click on the face I marked you with the red arrow
I don't have the message because we have activated the option in the settings to automatically create the axle system when creating a new catpart.
I am not very sure of this statement.
I agree with you, but a verification is always better to do it: we do not know a priori how that face is oriented to other components.
I have not even understood what the piece really is, they play in a very general way and I might be wrong:
1651089600315.webpif you refer to this flag .. the question of post #2 does it anyway
it works
if you do a tilted catpart and click on the face indicated by the red arrow ... the view in the catdrawing becomes orthogonal to the face you selected for the table setting
However the right job is not that, but that of having a proper axe system
this could be a method to speed up the temporary solution
1651090484756.png1651090538878.pngThat post @emanuele fat I feel like a plant of a shed
it works
on this no doubt! I often use your system too, because it is very quick.
my consideration was not to have the certainty of orthogonality between the various parts of the piece, especially when the 3d model is not made by me.
that post of @emanuele fat seems to me a plant of a shed
:eek: I had exchanged it for an electronic card😄
I insert a new non-existent part. nessumessaggio appears.
the new part created on the fly has the axle system.
but no message.View attachment 65419
I think it's a "command" problem.
from the menu insert->new part should not appear the message.
if you use the command from the toolbar (see image below), what happens?
to me the message appears only in this second caseView attachment 65420
This way I have the message.
but I tested with custom settings.
If instead I refer to the original ds settings I can reproduce what you have said with the automatic creation option of the active axle terna.
so in my settings there is some other option to adapt
ps: test with r30
ps: test with r30
I only checked with the old version r24-.
you probably need to check something in personalizations from management, but I don't know where to put hands for this
