macro to create display status, hide, save as part, save as step: help
reggio
hi to all, in the previous episodes, I realized that, for my machines, the least worse way to simplify, lighten and hide the "secrets" before sending model to the customer is to use the hidden command joined to state of display.
as the operations are repetitive and monotonous, I put 2 buttons (hidden/show comp - exhibition comp hidden) in good view, 1657798200553.webpso I create new visualization status, name it, ctrl+a selections all, hid everything, show comp hidden, select the components to show, save as part, open part and save as step: ok it works, but remains monotonous ...
I thought I'd record a macro to run every time, so I could limit my intervention to the selection of parts to show and nothing else...
sin that the macro hide.swp memorizes, as well as the commands, even the names of the parts and the names of the files that save as part and as step, while I have the need to select by myself the parts to show and save by name that seems to me...
you would be able to guide me in changing this macro record so that after the macro launch do:- automatically creates new display status called "hidden" (always the same, I'm fine)
- Automatically select all that contained in the axieme (type ctrl+a)
- in automatic preme command hide/show components (to hide everything)
- automatic preme command shows hidden comp
- let me select all the components that I want and continues when I press "exci from exhibition-hidden"
- automatically returns to the previous display status (what shows everything)
- in car saves the axieme overwriting (I also save the new state but so that you see everything)
- in car returns to the display state called "hidden"
- automatically save by name as part (use the same file name but always in folder c:\buttami (of course not reactivating hidden or suspended parts)
- automatically opens the newly saved part file and saves it by name as step (use the same file name but always in the c:\buttami folder.
There's someone. (@jenuary @massivonweizen @... ;)) that could guide me in changing the macro attached?
... automatically gives me a transfer of 1000 euro :roflmao: :roflmao: :roflmao:
:roflmao: :d :roflmao: you're right, you're just missing coffee' and sending receipt or invoice.
Well though, jokes aside, in theory "the structure" of everything was recorded and the commands there should be all, right? I should "just" know and understand how to do to:
- select all "objects present" (not "all specific codes of this example set")
- put a "freedom selection" between the command show hidden components and the command show-nascosto (so let me select all the components that I want to see eventually)
- "fix" the c folder:\buttami as default save folder
say it is not so simple to change (for a professional expert with noble soul and innate talent)?
... oh, then .. if there is to pay some ten or hundreds of coffee to make it work and understand how it works, we can do ... instead on the 1000 coffees, we risk the nervous crisis;)
take a look at the bee manual on the runcommand method, this allows to recall the commands, a sort of autolisp si autocad.. .
You should get to a good point
[ Map / Picture on page 13] unjustly
انا ليي ليي
It'll be a walk
. pant pant .. seems easy to understand from where to start...
the downloadable documentation from the sw site prevented me because I bought only the vers. 21 but not the update and assistance therefore nothing ...
I am trying to follow this course but, in English it does not help much, moreover it starts from examples that little fit with my needs and I lose myself between what will serve and that not (at my age, the ability of concentration is equal to that of doris)
.... @jenuary It would take a little pusher with explanation ... I already have the tokens for coffee and also some discount for beer, the non-alcoholic... what do you say? Huh? Huh? ;)
I have long been evaluating the writing of a book in Italian, within reach of all
ah but then it is perfect, I the questions of the average ignorant, I know them all and in this I can support you very strongly! ;)
I have already in mind the title of the first chapter: "macro to create display status, hide, save as part, save as step"
... cheddisci? Shall we leave? :
as the operations are repetitive and monotonous, I put 2 buttons (hiding/show comp
ciao,
What kind of quest?
