how to transform this plastic object into...
  • Thread starter Thread starter Niccolo^
It would serve an alchemist.
or give more information because this, as it is written, is a request without sense
if significant quantities were foreseen, it would be obtained without die casting problems; in plastic there are four thread inserts that in aluminum would not serve as threads would be processed directly on the metal.
if instead as I think it is a few pieces, if not a single piece, you have to look for a craftsman who gets it from the full leaving the processing of the non-functional parts.
per te, coffins.
Do you know that you wrote in the creo section and therefore it would be implicit that you talk about modeling and therefore the fact that it is plastic is irrelevant?
Then in the specific you do not transform it, but you build it into different material and nobody knows what your difficulties, skills, resources are.
There are many online sites that make 3d printing service, machining, stamping.
After loading the mathematical model you can receive an instant quote with relative delivery times.
You can try with this system.
