CAD_MAN
I'm trying to create a standard part similar to this. But as far as I know, I can only change the size.
in this standard, as you can see, I have to change the number of holes for the screws and also the distance between the shaped holes is not the same! I also need to insert the screws into the standard, which will fill all the holes, in order to create the cut in assembly.
Any ideas?
can we suppress and reactivate functionality in standard parts?
in this standard, as you can see, I have to change the number of holes for the screws and also the distance between the shaped holes is not the same! I also need to insert the screws into the standard, which will fill all the holes, in order to create the cut in assembly.Any ideas?
