alberto64
I have old sw files without custom properties, does anyone know if you can import the list of fields from one model or other?
the contents yes, of course, but the header of the fields there is no possibility to import them? Do you know if there are macros already written?add. everything can be added or removed....to handle one by one. or with macros...but the contents you have to stick them.
thank you, it works very well, you can do at most 4 files at a time better than nothing, I found the author on linkedin, see if he answersI use a software that copies the properties from one file to another.
You can download it qui has only one defect that can work a limited number of files at a time.
I've never been able to track the author, so I can buy a key to clear it, it would be interesting if someone can use it freely
same tactic my...Thank you, it works very well, you can do up to 4 files at a time better than nothing, I found the author on linkedin, let's see if he answers
