soho2025
hi to all guys are new on this forum, and I write this post to ask you for help on a problem of mechanical engineering, hydrodynamics, advanced level that I am not able to solve and I hope that some of you definitely better than me can help me.
the problem is as follows: (I attach plumbing diagram, sorry I know that it is not accurate, I put it on the flight on the pc copying it from the book of the exercises, unfortunately it is not in scale but it should still be useful to understand the exercise)
to find the entity of the force that must be applied to the hydraulic piston, placed in the blue tank below, containing 48 thousand liters of water to empty it in 25 seconds through a tube of diameter 0.9m and length 1 m that shrinks to a diameter of 0.25m and length 105 m connected up to the spherical reservoir also of 48 m3 place at the top.
density of water fluid at 20 degrees celsius = 998,21 kg / m ^ 3
dynamic viscosity of water at 20 degrees celsius = 0,001002 pa.s
calculate :
I tried to solve it, calculating the necessary force and I get about 3000 kn with a power of 1050 kwh, but I don't know where I'm wrong and the result does not lead with that of the exercise. I calculated the load losses in the 2 shrinkages, in the 3 curves, the continuous load losses and the flow force necessary from the tank, to calculate the power I calculated before the work but nothing to do.
I thank in advance whoever can solve the problem and help me.
Thanks
to find the entity of the force that must be applied to the hydraulic piston, placed in the blue tank below, containing 48 thousand liters of water to empty it in 25 seconds through a tube of diameter 0.9m and length 1 m that shrinks to a diameter of 0.25m and length 105 m connected up to the spherical reservoir also of 48 m3 place at the top.density of water fluid at 20 degrees celsius = 998,21 kg / m ^ 3
calculate :
- total force to be applied to the piston to empty the tank in the specified time, considering the continuous and localized load losses, (very low-wrinkle steel tube)
- power in piston kwh
Thanks
