distinguished advanced base
emanuele grasso
I have several questions about the distinct advanced base:
1. how do I connect the distinct base to the ball. . I give an example of the attached image: in the table I would like a column (the first) with "number" header and then all numbers equal to the balls..like the distinct normal base to understand us
2.How come I don't update the properties I want? in the second photo I added material and weight
How come I don't fill out this data while giving in part all the correct functions?
you have to enter the standard -> drafting choose your file *.xml
and customize what you want
ps: you must enter as administrator
I was trying but if I generate an iso + ball of a byproduct does not generate the distinct advanced base only of that byproduct but of all the project
and in addition it continues not to compile me materials and weight:
the variables you need to insert as from image below
then if I don't remember badly. .
1) you create the 2d view of the underproduct by opening it in a new window and not in the product father.
2) inserts the advanced distinction, clicking first on the created view and then at the point where to place it.
3) then you make the ball
Let us know. so it is useful for others
opening it in a new step generates me the distinct base only of the byproduct.. So much stuff:)
continue, however, to remain the problem of the material and weight: the material marks it with the hyphen and the weight all 0 kg
I am doubtful that in the properties of the cat part you have not inserted the weight and the matter
I didn't put them in. But if I give birth to the distinct normal base, I fill them all.
sisi and I connected the material through the formula command to the wording that I looked for in red. the acronym of the aluminium that I read created in my material library
I continue the discussion because I need to solve this dilemma. .
but the properties that modify from the xml' (capture1) must be equal to the name of the variable (capture2) or its type (stringa, mass etc) ?
I mean, that kind of "mass" property should be weighted?
must be the same certain.. both as name and as type.
you can't put a "weight" variable created as a "length" variable
how did you insert the test entry into xml files? I can only choose voices in the curtain!
