inventor
18_a
good morning, i'm here to write about the project i'm doing.
i would need to understand if with inventor professional 2022 i can change the measurements of a drawing already executed, thus avoiding to start over. could you give me some useful advice to save time and effort? thank you in advance!
your question is frankly incomprehensible, you should also post in the inventor section, as it is specific to that software.
excuse me then if i didn't write in the correct section, but it's the second time i do it.
as for my question i meant that, if i find myself a drawing already made and complete and, having to make another identical, but with different measures i can possibly recycle it by changing the measures through some setting? for example, i already have a drawing of a toothed wheel with a certain radius, having to make another one with a different radius, can i change the radius through some setting without doing it all over again?
the ray is a random example, i hope you understand me. . .
excuse me then if I didn't write in the correct section, but it's the second time I do it.
As for my question I meant that, if I find myself a drawing already made and complete and, having to make another identical, but with different measures I can possibly recycle it by changing the measures through some setting? For example, I already have a drawing of a toothed wheel with a certain radius, having to make another one with a different radius, can I change the radius through some setting without doing it all over again?
The ray is a random example, I hope you understand me. . .
first of all you have to understand the logic behind a cad 3d as an inventor, the table is dependent on the part, to do what you say you just have to make a copy of both, renamed them and keeping them connected, changing the part you will find the design that automatically updates.
the applicant opened the discussion in inventor, it would be the case of moving the answers on that argument otherwise you risk having two equal discussions traveling parallel.❏18_a in the future when you are wrong to open a discussion contact the moderators to do the corrections of the case. I also invite you to write more specific titles, not kilometers of course, but that clarify the topic of the discussion
Yes, sorry again
