TETRASTORE
the rectification of the seat of the bearing is generally carried out to dive, so it is not indispensable but it is advisable to rectify also the shouldering; time and its additional cost are not relevant.1) in the event that a bearing blocked by a shoulder only works radially it is right not to rectify the shoulder and therefore to predict a throat x rectification type and ? therefore basically I go to rectification the shoulder only if there were axial loads on the bearing and in that case put a throat type f
sì.So I take 51 mm from the shoulder and start the quarry (obviously towards the opposite side of the bearing) is correct?
sì.then should we put a tolerance on this quota?
