rotation of a piece
  • Thread starter Thread starter 18_a
18_a
Good afternoon, I write as I have some problem with autocad.
I have to do a set therefore, the idea is to copy my previously designed pieces and place them properly, but when they select them to rotate them not all the lines rotate, but only some, therefore I find myself redesigning almost all the piece. How can I solve this? Thank you all in advance, for availability!
so you would think you would also select the lines, but I think you lack some detail in the explanation. .
Of course the ideal would be to create blocks so that you select everything easily and mon lose nothing
even if I put it as block rotates only some lines, more precisely, what is the wheel contour, while those that are the inner lines of the piece no...
ever more mysterious!
Are we going to guess between the thousand variables of design and your maneuvers or attach something like an image or even the file?
then beyond this file I hold another open one that I look at and nothing more, but I do not think it is related to this, because this problem related to rotation has arisen randomly from nothing.. .
I also realize that autocad goes to snaps, always from nothing, so from one moment to another.. .
Okay, now we have a thousand variables -2.
do you want to attach this blessed file, which at least we understand how it is done, or should we exclude to attempts all possible causes and arrive at 200/300 posts, if all right?
if an object is not rotated can not be wonder how many causes: blocked layer, no selection, parameter constraints, user variables.
However massive is right: attaching the dwg file would simplify the problem resolution
the thing that does not fit, is that a block with some entities on a blocked layer, rotate only the unblocked entities. never heard of anything like that, from my poor 35-year-old soft knowledge.
I think otherwise. the block did it, but it is not turning that (vamping the creation of the block).
"autocad goes out of nowhere..." will the snap? f9 key?
"I've always kept the same layers..." It's not a blocked layer that's self-destructed or self-named. . .
to me it seems so much like "I entered the car, put the key in the picture, pressed the accelerator but the car does not move" (and then discover that the key did not turn it).
even if it would have been easier to share with you the file I preferred to arrange everything independently, line by line, as for the next day was expected to deliver the processed. I thank you for your help and apologize for not responding, but this project is putting me in serious trouble... I hope you understand
Okay, but now that you've solved the delivery emergency processed, don't you care what was wrong? If you are in the same situation within a week/month/examination, go back to the problem by praying the forumists to respond immediately because you must deliver the processed?
that then, if I had collaborated with those who wanted to help you, from Wednesday to yesterday there was time to figure out where the problem resided.
massive asked you the file on Tuesday, by the way...
I'm gonna fuck you, but you're gonna want to fix this, or not? !
________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Finally, an unsolicited advice: when you ask a question (chat, forum, mail), before you press "send", read everything and ask yourself if a stranger has all the necessary elements to answer.
because you know that you are using blocks, extruded solids, rotation, united, surfaces, 3d elements found on the web...but who reads you not!
so if you ask for lights on a forum because your washing machine no longer drains water, at least the model of the washing machine write it. and if you have already checked and cleaned the filter, write it. and if during the last wash you heard a strange noise when the pump was in operation, write it. and if in the drain you see pieces of white solidified stuff, write it......
we understand but, as you have been explained before, in cases where you seek help it is good norm to attach at least (as a minimum mayor) a screenshot of the work, this to give the possibility to those who read better understanding the problem and get more 'fast tips.
also serves for those users who encounter your own difficulties.
I have a hard time understanding.
Ragnol, demand too much.
are millennial, so of the "research of the solution", of the "learning from the experiences of others" know very little.
are used to everything and immediately, immediate solution and so on.
you seem to me (like me) the type from "research of the English dictionary that contained technical terms" in the library... because that was the only way.
today the millenial go on wikipedia and have solved (believe).
if you raised the file to my first request most likely in half an hour had the solution or at least a concrete answer.
since he arranged everything independently could avoid asking the question so he would save him 10 minutes of time to devote to the selection of lines and we to read and make unnecessary assumptions.
Since I always think bad of people, until conclaimed contrary evidence, I would say that he did not annex the file for fear that some comrades would fuck his job.
apart from the millenials being from 1980 to 1996, so today they are between 26 and 42 years old.
I think it refers to the so-called z generation or zoomers from 1997 to 2012. ;) or to some university late who is three to 35 years old, but are few.
