contour of the text in the restraints
  • Thread starter Thread starter gbarattin
gbarattin
Good morning to all, I would like to know if there is a variable or something similar with which you can increase or decrease the distance from a text in a deduction. ie when we have a region or a polyline closed with inside a text or textm, and you click inside to treat it all, around the text you will have a space free from the dash, can this space be modified or is it fixed?
if you use mtext you have the possibility to apply a background mask with an offset that you define
Yes, but that's not what I want, it's not okay, I just thought there was an offset variable to change, sin, however thank you.
Why do you say it's not okay? would do exactly what the variable fantomatic should do. . .
but do you mean I have to do the restraint first and then put on the text with the mask? It can work, but I usually treat it last, after I put all the texts and also I saw that the blank space of the dash does not even match the rectangle of the mask, is different. All right, come on, it doesn't matter, it's not like I'm freaking out. but then who decided the space around the text? there will be some extent the measure of the offset.
with the solution of tristan, unscrew the dash from the text, in the sense that if after you have to move or edit the text you do not have to review the dash.
by tracing the area with the text inside, you have a better contour, but if you need to move/modify the text you will also need to edit the dash.
against the solution of tristan obliges you to have the text "above" deduction, but it is a simple operation even on thousand thousand texts. You're feeding them and give them a draworder.
It's just a different design organization.
