mirrored and distinct cut object
  • Thread starter Thread starter CRAZYMAD
CRAZYMAD
I created a speculative part on a welded side and I made the table
but when I want to insert the cut of the specular part the function is disabled
Where am I wrong or how do I solve it?
you have to transfer the properties of the separate cut from the father
I use the release 2019
and this and what I see
check the option indicated when you create the mirrored part, or open it and enter the check... .Immagine 2023-03-30 154556.webp
Why is it not a part created with the welding functions correctly?
I don't know.
If you can attach a file would be better.... .
then to give you ul feed back
the part and created correctly so much is that if I put the part on a new set the mirror and the quot is perfect and for the moment I solved so because I was in strange urgency
I've been dealing more and more times what could be there but I haven't found anything
I don't know.
If you want I send you a copy in private you know it's a project where I work
If you want, I'll take a look. .
