indication areas with different slopes with civil3d
  • Thread starter Thread starter fabius69
fabius69
good morning, is it possible with civilization to represent areas on curved level surfaces with range of slopes?
for example by retinating areas to different slopes?
Thank you. fabio
it is possible; use a surface style in which the gradient analysis is visible, then the "analysis" tab of the surface properties sets the various ranges
Thank you so much tristan.
I would also need to have a table of range of gradients (with various intervals). In practice I must highlight the areas of a slope that have excessive slopes for the installation of photovoltaic panels.
I solved! thanks cmq, hello
how beautiful the spirit of sharing. . . .
surface properties --> type of analysis --> slopes indicate the number of intervals and in the detail part range mark a minimum slope and a maximum
for the table: select the surface, from the menu add legend --> gradients --> static
Bye. fabio
