unusable and undeleteable icons in the work area
  • Thread starter Thread starter Piero C.
Piero C.
suddenly some icons have begun to appear on the work area that even if they are deleted reappear. these are the terms that appear by approaching the dart: "import shape files" and "abc myhtach" someone can help me understand how I can delete them permanently or do so as not to see them more on the work area? moving them into the toolbar and also fixing them reappeared in the work area and beyond all they are completely unusable. Thank you.
after removing them from the work area?
which applications have installed or loaded?
not being autocad commands, you obviously installed some application that modified the software startup or the acad.lsp
I have not done special operations for the moment. I wanted to understand what it is and why they reappeared even if they were eliminated. one of the things done lately was to delete a folder with old uninstalled inventor files long ago. Could it depend on that? Thank you.
if you have not saved the work area it is normal that icons recompany, it is like making a change to a design and you want to close it without saving and then wondering why there are no more changes.
I'll try. I'll let you know if I did.
So you're aware you've installed one of those applications, and you wouldn't do anything weird in the last few days?
thanks, solved thanks to the intervention and kindness of tristan. It is clear that if one turns to those who know more it is precisely because he does not. greetings
