Antares89
Good morning.
from a few months I entered the world of lifting equipment design. From the beginning, I get a problem that I haven't solved yet.
which model should I use to dimensional the lifting point of a mechanical component?
I have done various research on regulations, fem / en 13001 / en 1990 / asme bth-1 / cnr / norsork and has always been a hole in the water...
the problem is that all these regulations consider only couplings pin hole and then attach the hook to the grill.
I have also tried to look for the method of sizing of crickets and gulfs, but they are made according to norms that define material and flow dimensions, so there are no mathematical models.
I tried to use fem calculation methods, but the results are exaggeratedly conservative, not to mention that the design through fem is not covered in the regulations and there are no instructions en on how to apply it.
I was currently using as a model for calculating tensions a double ink beam with concentrated load applied to the center. a fairly conservative method, which sometimes generates such a large section not to enter into the lifting hooks. in fact I have gone to set as attacks only pins or crickets.
Now a customer has asked me for a certification on an existing equipment and the working load limit that I find is 6 times lower than what they are currently applying without problems.
below an image of the equipment, the point in question is the round folded to u, but I have the same problem even when the lifting point is made within a sheet.
This question is exhausting me because I haven't found the answer for 8 months and I have been confronted with all the designers I know.
