fusa
Good morning to all,
I'm a new engineer and I've just started working in the company.
I was asked to verify the possibility of changing the material of some toothed wheels, passing from steel to a quieter material. They asked me to deepen the tecapet white, the nylon pa.6 and the bachelized canvas. on the internet I have not found much for the sizing and verification of dense wheels in plastic material so I ask if someone has already had experience.
as I found between the two plastics does not change much, instead for the third, the canvas, I do not find enough data and I do not find what the benefits of this solution can be.
above all I would like to know for the verification that value I have to use? tensile strength? Elastic module? because the person in favor of the bachelized canvas argues that the value to consider is the parallel/perpendicular compression resistance to the layers, which I have never heard of in the verification of the dentate wheels.
I also read that we have to take into account moisture, since I do not find it for the bachelized canvas.
the toothed wheel is mounted on a machine that works continuously and with commuting motion, continues to change direction of rotation (I don't know how to say it technically) and is subject to a force on the tooth of about 280 n, with radius of 150 mm.
Thank you very much in advance and hope to have been clear.
