created a custom part. x frame generator
  • Thread starter Thread starter jiji_akiko
jiji_akiko
Good morning to all,
I've been trying to create a library for days to use it with the chassis generator, and for a simple component I have no problem, but my purpose is another: to create a tubular with the ends crushed on the side and then insert it into the frame.
In the end I need to change only the length of the tubular extrusion, while the crushed funds I want to remain at the same distance.
I'm looking at evidence, but I'm getting the doubt that something like this isn't feasible to do.
Can someone light me on this?
I leave the detail attached to give an idea. (the part marked in red is the one that should not change)1697967601577.webp
Hello, peppe,
Thank you, but finally after 3 days not to sleep on it, at this very moment I managed to do it!
I will now save a lot of time and the project will be more correct.
Since it's a topic treated a long time ago you could illustrate the solution so that you can help in the future other users who will need it.
Right!
Do you think you better put the solution on the old topic?
