macro to export dwg,pdf,step with folder selection
  • Thread starter Thread starter FIGOR71
FIGOR71
Good morning to all, I hope you are well seen the situation in Italy. .
I find myself with the need to create dwg,pdf files and step files of each table of solidworks, and turning on the internet I found the macro attached. .
I kindly ask if someone is able to change it, so that I can choose the folder where to extract the generated files..(At this moment I type them in the native file folder)
Thank you in advance and wish you a good day
Good morning to all
I created a macro (thanks to the code found by one of the deepak macros combined with one of mine) that should do as follows;
-open a folder selection box (where the user selects a folder)
-open all drawing files in the selected folder (one by one, one after the other)
-check if there is a folder called "pdf", otherwise create a directory
-Save the open design file as pdf, creating the name saved as from custom properties in the reference model
-close the design
-pass to next
now in my code below (and I attached the macro file because the folder tab is attached) the macro will complete a drawing, close the drawing and show the msgbox if the folder "pdf" exists, if the folder does not exist will create the folder, save the open design, close the drawing and fail on "sfilename = dir"
if comment "if dir(pdfpath, vbdirectory) = "" then mkdir pdfpath" and create "pdfpath=currpath" works perfectly and saves all designs in the selected directory.
Can someone help me solve it, so that you create the pdf folder and save pdf? ?
explicit option
dim swapp as sldworks.sldworks
dim swmodel as sldworks.modeldoc
dim sfilename as string
dim vfilename as string
attenuated path as string
dim npath as string
dim nerrors as long
dim navverte until
dim swdraw as sldworks.drawingdoc
dim swcustprop as custompropertymanager
dim swview as sldworks.view
dim configname as string
I am so long
dim valout1 as string
dim valout2 as string
dim solvedvalout1 as string
dim solvedvalout2 as string
dim leaving as string
dim nfilename as string
dim swdocs as variant
dim pdfpath as string
weak currpath as string
dim partnodes as string
subprinciple()
tax swapp = application.sldworks
path = folder("select a path/folder")
path = path + "\"
sfilename = dir(path & "*.slddrw")
run until sfilename = ""
set swmodel = swapp.opendoc6(path + sfilename, swdocdrawing, swopendocoptions_silent, "", nerrors, nwarnings)
swmodel tax = swapp.activedoc
Swadraw tax = swapp.activedoc
set swview = swdraw.getfirstview
set swview = swview.getnextview
set swmodel = swview.referenceddocument
pathcurr = left(swdraw.getpathname, instrrev(swdraw.getpathname, "\"))
pdf route = current route & "pdf"
if dir(pdfpath, vbdirectory) = " then mkdir pdfpath
if swmodel.gettype = swdocpart then
partnodes = mid(swdraw.getpathname, instrrev(swdraw.getpathname, "\") + 1)
partnodes = right(partnodes, len(partnodes) - 14)
partnodes = left(partnodes, len(partnodes) - 7)
partno = mid(swmodel.getpathname, instrrev(swmodel.getpathname, "\") + 1)
partno = left(partno, len(partno) - 7)
set swcustprop = swmodel.extension.custompropertymanager(swview.referencedconfiguration)
Configuration name = swview.referencedconfiguration
swcustprop.get2 "description", valout1, solvedvalout1
swcustprop.get2 "revision", valout2, solvedvalout2
nfilename = pdfpath & "\" & partno & "-" & configname & "-" & solvevalout2 & " & partnodes
swdraw.saveas3 nfilename & ".pdf", 0, 0
elseif swmodel.gettype = swdocassembly therefore
partnodes = right(partnodes, len(partnodes) - 11)
set swcustprop = swmodel.extension.custompropertymanager("")
nfilename = pdfpath & "\" & partno & "-" & solvedvalout2 & " & partnodes
You're gonna end up
swapp.quitdoc swdraw.getpathname
set swdraw = nothing
set swmodel = nothing
snomefile = dir
continuous cycle
msgbox "all done"
end
Good morning to all
-close the design
-pass to next
explicit option
dim npath as string
dim nerrors as long
dim navverte until
I am so long
subprinciple()
path = path + "\"
You're gonna end up
snomefile = dir
continuous cycle
msgbox "all done"
end
Can you attach the complete macro?
with the code so copied and translated it is difficult to help you.
i have created a macro (thanks to finding code from one of deepak's macros combined with one of mine) that is supposed to do the following;
-open all the drawing files in the selected folder (one by one, one after the other)
-check to see if there is a folder called "pdf" in the directory, if not then create one
-save the open drawing file as a pdf, building the save as name from custom properties in the referenced model
-close the drawing
-move on to next one
now in my code below (and i have attached the macro file because there is the browse folder module attached) the macro will complete one drawing, close the drawing and show the msgbox if that "pdf" folder exists, if the folder does not exist it will create the folder, save the open drawing, close the drawing and fail on "sfilename = dir"
if i comment out the "if dir(pdfpath, vbdirectory) = "" then mkdir pdfpath" and make "pdfpath=currpath" it runs perfectly and saves the drawings all in the selected directory.
can anyone please help me solve this, so it creates that pdf folder and saves the pdfs in to it??
option explicit
dim path as string
dim npath as string
dim nerrors as long
dim nwarnings as long
dim i as long
dim resolvedvalout1 as string
dim resolvedvalout2 as string
dim partno as string
dim currpath as string
sub main()
set swapp = application.sldworks
path = browsefolder("select a path/folder")
path = path + "\"
do until sfilename = ""
set swmodel = swapp.activedoc
set swdraw = swapp.activedoc
currpath = left(swdraw.getpathname, instrrev(swdraw.getpathname, "\"))
pdfpath = currpath & "pdf"
configname = swview.referencedconfiguration
swcustprop.get2 "description", valout1, resolvedvalout1
swcustprop.get2 "revision", valout2, resolvedvalout2
nfilename = pdfpath & "\" & partno & "-" & configname & "-" & resolvedvalout2 & " " & partnodes
elseif swmodel.gettype = swdocassembly then
nfilename = pdfpath & "\" & partno & "-" & resolvedvalout2 & " " & partnodes
end if
sfilename = dir
loop
msgbox "all done"
end sub
-close the drawing
option explicit
dim path as string
dim npath as string
dim nerrors as long
dim i as long
sub main()
path = path + "\"
end if
sfilename = dir
loop
msgbox "all done"
end sub
I made some small changes, and added the browsefolder function you didn't post. to try the macro I had to exclude code lines that formed the file name to be saved, but you can reactivate them.
Thank you so much I try and I give you
Good morning I tried the macro but no works unfortunately I am not experienced.
I tried this macro that does to my case, this macro exports the active sheet to pdf in a folder called pdf, what I would like to have taken all the solidworks drawing files and exported them to pdf in a folder called pdf .
this is your second macro you posted, modified to read all drawings of a directory and save them with the same name of the drawing file with adding the value of the design "rev." property in a subfolder called pdf. you have to add references to libraries as from image.1699619541258.png
