copy property view dft
  • Thread starter Thread starter IBWorks
IBWorks
Good morning to all, is there a command that upgrades the properties of a table view, copying it from another view? For example, if I mistakenly put on the table all the views with hidden lines dotted visible and then in the end they wanted me hidden, now as now, I go into the properties of each view and the edit (but takes away a lot of time). I wondered if there was the system to change a single view and then with a command select the other views and make the same changes (a bit like copying quota attributes). Thank you.
a command that works as you say does not exist (it could be done through a macro to be realized).
However, you can change the properties of multiple views at the same time by obtaining the same result without the need for further command.
- select the views
- use the "property" button from the command bar
- select the views
You're right. I had already tried this system, but I was wrong not to select the views to one by one but through the window. In this way I also took in the odds and the property bar obviously did not appear to me... .
Thank you
