I can't open it because I have 2019, as written in my profile. You must have patience and wait for someone with 2021.
if you want to speed up time you have to put information that will allow you to understand how you managed files because the phrase
I can't understand why it sometimes appears not, but since I use solidworks it happens in other situations, like making the material appear in the cutting table. I have a table where the fe 37 material appears along with "undefined material" then pushing a little bit I reappeared everything fe 37 but I did nothing.... See Annex
If maybe instead of changing speech I would answer the questions you are asked, see post #25, you could find a solution or direct the analysis more accurately.
but why instead of letting them guess not attach those files?
attach the file: you immediately get the answer
do not attach the file: you ask n questions to know the settings you use to give an answer to which one, perhaps, solution or other questions will follow.
Good morning my name is tree-lined, while I thank you for the help you give me daily for all the technical problems I encounter between cad and design.
I connect to this discussion because despite the above indications, which I have performed several times, I can't show the threads at the table, I attach images with function shaft and visual result...in the part there are and you see the threads but in the table I can't show them, I also tried to make a new table with a different sheet format.
use solidworks 2019.
Thank you for your help.. .
I would say yes... see pictures. . .
I didn't specify it before and maybe you don't understand, but it's a set consisting of 2 parts that in the image. . .
Excuse me. .. always for clarity, in the design of the single part, not in the assembly, the threads are seen, as evidenced by image 08
