symmetry bond in assembly environment
  • Thread starter Thread starter Pralek
Pralek
Good morning to all,
I need to bind one particular to another, symmetrically, using a plan of the particular "a" compared to two surfaces of the particular "b" or two surfaces and two surfaces.
Thank you so much!
I try to explain better:
I have to focus a particular plan on two surfaces of the particular b A.webpor I have to center two surfaces of the particular a with two of the particular bB.webpfaces will not touch but must be symmetric. . .
if they are 2 parts:
creates a work plan in the part touching the 2 faces to
creates a work plan in part b touching the 2 faces b
constraints between them 2 floors
p.s.
as you see by posting some pictures immediately is all much clearer
p.s.
Okay, now I'm composing the situation: the two details come from contained center, so they cannot be modified by adding work plans.
in solid edge there was the possibility of a specular positioning without adding plans or without giving a distance.. .
if the components come from the content center, you have other possibilities
1) when you insert selections as personalized and sales where it serves so it becomes changeable
2) from the content center file, in the broswer select and button dx and open file path, open it save and overwrite if it is its library.
3) if it is in a custom library from management panel--> editor you look for your library and respective family and edits saved and close
other option
put the positioning quota during the bond
other option
Thank you very much.
Unfortunately I will opt to add a plan in the axieme, parallel to a plan of origin, passing by a point to which I will finally attack with the plan of the particular in question.
excellent right to overwrite the file inside the browser!
the third possibility, however, I don't understand it at the bottom: apro editor, I look for the family then?
what I understand about the family is that you publish a file that will make it as a matrix (I don't know where it is saved), then when you create for the first time the version of that color then save the file in the browser folder of possibility n.2 you wrote me.
but how do I change the matrix of the family?
give an eye to this old post
