developed sampling - notes of bending on the view
  • Thread starter Thread starter MassiVonWeizen
MassiVonWeizen
Good morning, everyone, I have to ask you a question that no one in the office has been able to answer.
in the developed field view is it possible to insert the bending specifications in correspondence of the bending line?
i.e. instead of inserting the fold table and getting the corresponding sequence number on the view having in its place degrees and direction.
pure as an example I attach an image of solidworks (recorded by the forum) of the result that I would like to getIMG_20220727_150839.webpThank you very much.
Yes, it is possible.
in the example (flight) the call is set with the defined prefixes as you want: "piega in", "east corner. fold", "inside corner fold", "fold radius".
values "down", "45°", "135°" and "7.5" are extracted from geometry (respectively %bo, %bn, %ia, %br).
thanks, however you have to manually insert a note per line of fold and there is no setting in the view, or on the other hand, that inserts it automatically, correct?
that I know, it is possible to automate the thing only by using the "quicksheets" which are particular templates that already "contain" the visual settings of drawing, quotation and annotation of the particular to represent, but I find them too rigid for my taste.
what you can do, and that I do normally, is to save the types of recalls you need to use when needed.
in practice to make the type of annotation I described before (with all the plethora of indications), once saved I will go to call it to "apply" to the fold lines.
Thank you. @radioYou made it clear to me.
so far in the office no one has ever thought to indicate the direction of fold and therefore have fallen from the pear.
the recalls are handled on the company server and I should do it to those who make the settings.
Meanwhile I send to the supplier a couple of drawings with the table and see if the thing he likes then I will add the shot.
Good evening
you can use the fold table command, remove the table creation option, and activate the note creation option. in the note options define what to see in the call that is created.
Thank you. @delki, when I return to work after the holidays I will try as you wrote, urgencies allowing; Unfortunately being commands I use little now I struggle to make local mind about removing the table creation option.
I will update you next week
ciao @delki Could you kindly make a screen where the option is to create the note instead of the table? I'm also looking for a solution to this problem, but I can't find this option, I'm definitely not bono a
1661525535427.webpyou need to keep the call creation active and turn off the table creation.
if you also create tabela you can still select and delete in a second time
great, much better than the table. Thank you very much to all.
Hello, everyone. Thanks for the discussion.
I tried with "fold table" disabling the display of the table and saved the setting of what to display (%bo%bn): 1671007829086.webpis it possible to change the language of the indications "up" and "down" (%bo)?
by taking this post, I would need to display the intermediate fold lines,
Is it possible?
to the eye the two semigusci have drawn them "calandrate" and not with a sequence of folds.
if so the program does not draw fold lines that do not exist.
