the terna does not contain axes and is not selectable for repetitions. If you don't want to create anything you can use the orthogonal plan to the repetition direction, or create an axis from the intersection of 2 floors.Good morning to all,
do you know if you can select one of the axes (x,y,x) of the reference terna as axis to perform a linear repetition?
in case of affirmative answer, how should I do to select the axis?
thanks for the answer,
good day and good work
