motor for structure photovoltaic panels
  • Thread starter Thread starter Dailon
Dailon
hello to all, I apologize from now on I am anything but an engineer, I am a fan of DIY energy. in my search for a suitable engine for my idea I came across this forum, if I am outluogo thank you and do not go any further, tell me you. I am thinking of a structure to be positioned on the terrace with 4 panels that can rotate from southeast to south-west. I'm looking for a motor, even a snap. the excused idea is really elementary and I put it from the third media :) to rote the structure on a fixed part on a pin (center of the circle). on the opposite side as a hypothetical radius, a motor also on a pin hooked to the structure and under a wheel moving to 360, so it can indulge the arc that must draw. Is that a beaver? Thank you very much
hi dailon, as data is a little bit, to clear your ideas I recommend you look on youtube: "Solar chaser diy", there are dozens of projects, from which you can draw inspiration, with also the relative structures, motorizations and drives controlled by arduino or other and on the net also the lists of programs to command the engines according to the position of the sun.
try to look at the various solutions then if you have doubts expose them; We're here.
I kindly ask a moderator if you can move this discussion in the section: alternative energies.
