radio
Hello, everyone.
with se2022 I sometimes find myself dealing with corrupt family assemblies (for now it happened only with axioms made with previous vers.).
in practice when I open one of these assemblies, if you ask me correctly that family member open but then, open together (visually it's okay), I find myself with the drop-down list where the various empty family members should appear (see image), to also the family table is empty!
At this point I can't do anything anymore, I can't add or remove components to the axieme, I can't make tables containing this together, I can't save the axieme even as a copy.
Does it happen to any of you?
Does anyone know if there is a remedy?
maybe some macro that analyzes the axieme and corrects errors/inconsistencies within it?
I also tried to feed it to solidedgehousekeeper-v2024.1 but it goes wrong (except from hresult: 0x80040227, v.log below).
log di solidedgehousekeeper-v2024.1:
"c:\a\elimina.asm
error processing file
system.runtime.interopservices.comexception (0x80040227): eccezione da hresult: 0x80040227
in system.runtimetype.forwardcalltoinvokemember(string membername, bindingflags flags, object target, int32[] awrappertypes, messagedata& msgdata)
in solidedgeframework.documents.open(string filename, object docrelationautoserver, object altpath, object recognizefeaturesifparttemplate, object revisionruleoption, object stopfileopenifrevisionrulenotapplicable)
in housekeeper.form1.processfile(string path, string filetype, application dmapp)"
log di solidedgehousekeeper-v2024.1:"c:\a\elimina.asm
