Ivo99100
Hello, we are a group of mechanical engineering boys and we have as a task to design a biella disassata da foundria, with the obligation to use a steel for castings. do you have any advice that only the experience can give?
we have as only given the maximum load on the head of the piston to which our biella will have to resist.
not having ever faced this design process, we have no comparison, quality that we may be able to find here perhaps.
here we have that the closing screws of the lower shell, that is of the hat of the head of biella, are subject to traction.
if the girls are slow you have:
if the biella are fast instead it is evaluated:
and finally a test to fatigue.
Where is the annex?Once we choose the suitable bronzine we have verified the sizing through the annex.
Sorry I meant the attached image. we related all measurements, in the first case according to the diameter of the biella eye, in the second according to the width of the arm.Where is the annex?
for the "part before" you can be useful This is document and also quest'altro..I also attach design trace, to clarify the doubts about the foundry part:
