create a customizable block library with a lisp
christian_96
Hello to all:biggrin:
can you tell me if there is a lisp or macro (or even an external application) to create a customizable block library (I exclude from the beginning the palette of tools as a solution being unmanageable )?
I found the block manager's autodesk add. but it gives me a strange result.
I see you quietmante the tree of the created folders but nothing else, does not see the dwg files
Looking at a video tutorial I seem to understand that I have to set up the block manager with a batch editor
(I almost have the impression that all the files I go to insert should then be adequate with this system)
Is that so... or am I tonto? ? ? !
Is there anyone who can express his experiences?
I re-exhumed this 3d in the hope of solving the problem of block libraries.
the lisp reported on the page, of Roberto Portuese that I tried to contact but without answer, does it really exist? Is he somewhere? or there is a valid alternative to this.
I hope in your answers and for now I thank everyone.
gerry
Hello, I tried to search "tablet bugbubble of portuese roberto" but I couldn't find the software, did you happen to have a link where to download it? Thank you.
Give me a few days and publish the files in this discussion
in the zip file you find the pdf with explanations on installation and use.
Good morning.
some difficulties:
1) uploading the file with appload, despite the folder is not read alone every time I reopen autocad I have to reload the file tablet.vlx I entered the address "c:\tablet" as indicated in pdf and in "supports file search path" that in "trusted location"
2) missing the add4tablet.lsp file
3) I cannot find the tabletbb icon
4) I created a _linea command, but when I start, if then I go to recall tablebb again resumes the command line.
I then saw some videos on youtube (
) and I found very interesting these automations, which of course I would not be able to program. Is there a possibility of having a version?
missing files.
to have the program always available, upload it from load application / startup suite.
for the video, send me an email.
Thank you very much to what email can I write to you? I'm still finding trouble. I'm sending you an email
