save image with white background
  • Thread starter Thread starter solokite
solokite
Is there a possibility to save the jpg to white sondo having customized environment color in 3d?
I have always changed the color scheme (black on white) before exporting the image.
once made reprint the custom color scheme.
You can also make a macro.
albe grazi, I had thought about doing the macro of the same component but I have to do 3 img of the same math
for the first image the macro works for the other "I lose the macro" because it asks me to overwrite the name...how can I do?
make a macro that stops when entering the name of the jpg file, so write by hand the name
Record the macro leaving the jpg file in the folder so that the "overwrite" is also recorded. if the file is not present then there is no problem, the macro will work the same.
then obviously between one execution and the other will be your care to move/rename the file.
ah nothing I put my soul in peace; I did another macro to change the environment appearance
then maybe there is a way to assign the name automatically not univocal but we go on them until...
