evidence part in tree
  • Thread starter Thread starter ipstatico
ipstatico
Good morning.
I have a set with several parts and sub-assiem: how can you highlight within the left tree the part that I go to select in the cad model without having to use the command "find in the browser"?
Thank you. Have a good day.
in create selections the part and automatically is highlighted in the tree, without having to click further. Moreover if I want to select the levels above the selected part, right-click and he rises level. easy but functional
even with inventor if you select a part is highlighted in the left tree, of course if that part is nested you have to open the various levels. with located in the browser, maybe set as a quick command, with a click do everything.
other thing I recommend is to use the selection filters (priority components), always with fast keyboard commands, so as to select axioms or parts.
see guide:
Thank you. I started using component priority, I will create quick keys. but I repeat that in I create even if the part is nested is highlighted. Obviously also creo has some sort of priority components but if I remember well it is available at a drop down menu somewhere on the work window.
