Jachie
Good morning to all, I open this discussion to ask you a advice on how to make a reinforcement on a sheet metal part on pro-e wf5.
It is recently that I have looked at pro-e and I have not much experience even on the printed sheet, so every little advice could be helpful.
At work I happen many supports in sheet metal with pressed reinforcements, I press that I do not need the development of these supports, so even if I am not in the sheet metal part it is ok the same, the only thing is that I am easier and intuitive to make complex folds in sheet metal environment, I tried with punch and matrix but I just can't come out.
I attach an example of support to make the idea better, the incriminated reinforcement is what flows on the side of the support.
according to your experience, what could be the most correct way is quick to achieve this support with reinforcement?
Thank you in advance and I wish you good holidays! ! !
