flaviobrio88
I finally got the version with the module die surface design I immediately tested the module by loading a normal size element (so no for demos)
and that obviously had complex areas.
the result was impressive (they are part but it is true the module is impressive )
the procedures I used in order were:
balance
closure of all internal parts ( here I followed all my logic the flat areas I treated them separately)
Premilam
filling of imperfections for the creation of the outside figure
Figure (I have several sections available in this case I used only one type)
and finally a Agreement between the outfigure and the premier.
the time I took to do everything is about 6 or 7 minutes.
imho:
who does this kind of work knows very well that maybe 6 or 7 hours are not enough to get to the result I got in 6/7 minutes, another thing not to neglect (which I will test) is the fact that being completely associative parametric and therefore any modification will be made later (for example a precentinatura) the mathematics will update without having to do anything.
image attachment before and after
the video is here:
http://www.screencast.com/t/4drxkxpzu
balance
Premilam
imho:
the video is here:
