1:1 scale printing
  • Thread starter Thread starter Beth
Beth
Hello everyone.
I can't print in scale 1 on printer
a very normal view of proe.
usually use option ",based on zoom"
but nothing the print does not show in scale
on plotter instead I can. but it is very uncomfortable
go to design environment and create views when
you are working in model.
thanks to who can help me
Bye!
for my experience I avoid printing from model and put on the table, even if I can't even save.
But it's the only way I know to be sure to print as I want.
thanks for the answer,
I know the option you're referring to.
I must have tried it, but if I don't remember
badly with insufficient outcome. tomorrow I try again and you
Let me know.
soon
I tried but the result was a completely white a4 sheet
my hope was to see printed in real size what I had seen on video.
Perhaps the system reasons differently
Hi, hi.
I correct your procedure, but if I'm not mistaken, the system tries to print all the encumbrance of the object in scale 1
regardless of what you have video.
I make an example if design a 100 concentric diameter to a 1000 and video diameter
I only have 100 diameter I would like to print in a4 scale 1 result is a white sheet
as the diameter 1000 is obviously larger than the a4 format.
perhaps the most comfortable and safe system is the table .
I'm going to do more tests, maybe creating masks to speed up the work.
I welcome advice
I would like the design mask to keep the state
of model display zones.
Do you know the config option?
according to you you can create more masks with
different config settings? for example on a mask
yes option and on another no?
