DANI-3D
hello to all and good 2015.
new year new problem, is our destiny. I have a lever running around an axis with a pin connection, as the movement must be 10 degrees in 10 degrees I would like to have the opportunity to insert shots that help me position the lever in a simple and fast way, possibly without using animations, servomotors, etc., I would like to take the object with the handle and drag it to the desired point, or, in the worst case use parameters and relationships.
I would like to thank the rapporteur for his work.
thanks in advance and greetings.
