2 proe one does the sections the other not!
  • Thread starter Thread starter Half65
Half65
hi, I have 2 computers with the wilfire version m060 that have the same configurations. they always did their duty. apart from one that 3 days ago stopped me sections in the drw!! i.e.; it makes them in the window 'design view' that appears with double click on the view but then in practice on the table does not show me. the same drw opened on the atro pc you should see it!!! I already uninstalled and reinstalled the m060 but nothing... Is there anyone who helps me?
Hello half65,
generically I suggest you check that they actually have the same configurations, the problem is 99%.
I would first open the drw that makes the whims, and manually reload the fle of the settings "iso.dtl" check if you turn on some green ball.
Try and let me know, bye.
Hello, Moorish. thank you for the answer but in the meantime we went to the creo.
there is a problem of the type that... in the views to view them with hidden edges, or with various shadings I have to enter sight property and change them from them because if I leave default and then act on the general display of the design does not affect the views.
You say that iso.dtl is the one who handles things?
of strange problems I met a tide... and at the end of 90% were due from the configuration file settings. Trying doesn't cost anything.
Yes, we have two create, many things I have solved by copying the config.pro from one to another, but this does not solve me. Now I ask the ptc then I tell you what it was. Hello and thank you
