mauror
Good morning to all
I'm struggling with a problem I can't handle.
I can also find it difficult to explain so I attach an image.
the amber color tondino as well as the support with clamp are fixed (the support with clamp varies the position according to the piece to work). on the amber tondino is mounted a band (green) that can slide and rotate on the tondino. another face (blue) is mounted on the green one on the passing hole of the screw and has a rotation movement.
On the other hand, on the support with clamp there is a green trangolar that has a rotation movement. to this is mounted a band that also has a rotation movement.
I have to align the axes of the two blue faces so that we can pass a round. I also attach the dwg for those who want to see it better.
If you can give me a tip I thank you infinitely.
