claudiaclaudia
Hello, everyone!
I have to put in plants in 2d of the blocks that provided me in 3d, I naturally care only the view from above.
since:
- The blocks are hundreds
- in every design I should use several
- the scale in which they are saved is also different from that of the plant that I should use as a base
- I would like to avoid creating very heavy files
I would like to understand if there is a way to insert only the 2d view from the top of the blocks (without seeing all hidden lines) or if there is a way to transform them quickly.
Help!
claudia
since:
Help!
claudia
